Hello all,
I have 8 rel perm curves taken from the same well. I'd like to use the modified brooks-corey method to normalize/average the curves.
Can anyone share a document that has the details of this process?
best regards,
Tarik
Printable View
Hello all,
best regards,
Tarik
this is an interesting reading material to help you sort the problem using modified brooks-corey method
[url]http://www.ars.usda.gov/SP2UserFiles/ad_hoc/12755100FullTextPublicationspdf/Publications/timlin/brookscorey.pdf[/url]
I cant think of a specific article - but the steps are as follows assuming krw, kro curves.
1. modified corey asserts: krw ~ Ew*Swn^Nw , kro ~ Eo*Son^No where Ew, Eo are constants and Nw, No are the constant exponents. Swn Son are "normalised" saturations.
2. Swn = (Sw-Swir)/(1-Swir-Sorw) , Son = 1-Swn = (So-Sorw)/(1-Swir-Sorw)
3. Swir is the irreducible water sat. Sorw is the residual oil sat. ( that vary sample by sample)
4. For each of your samples your need to identify Swir, Sorw ( not as easy as you think - esp Sorw) then calculate the equivalent Swn values in the range [0,1]
5. Plot all the curves on krw, kro vs Swn * do they look the same ? ( this is where the fun begins) - do you average / discard / bin ??
6. Some folk normalise the y-axis too per sample Ew'=1=krw/krw_max=krw/Ew and plot krw' , kro' vs Swn ( I tend not to do this as there's more info in Ew than Ew' )
You will find that ALL lab data need to be corrected - and this is best done by iteratively fitting Nw, No, Sorw via excel until you get a good match. Corelabs report Sorw from the highest Sw achieved - this is usually not the 'real' Sorw. Similary Steady State coreflood produce different Sorw's than Unsteady State and centrifuge tests ( for good reasons). ( I recommend doing this is general - but this wasnt the question you asked). You will notice that I left Swir out - as this variable tends to be "better" defined by lab data .... its usually Sorw that is the focus.
I've noticed such questions arise time and time again - if you want to send me your raw data - I'll have a look and provide a step solution for the whole group that the admins can make a sticky ( if they want). Take all mention of the reservoir off the data sets.
My experience is that up to 50% of SCAL data is often "off trend" for various reasons - and the user needs to seach for the "jewell" that are left .... ( leave me a message about how to contact you)
The steps listed above are fairly easy to do ... but further refinements may help particulary if the 8 data sets come from very different poro-perm sets.
itag
From anihitas link you may also find this interesting
[url]http://www.ars.usda.gov/sp2UserFiles/Place/53102000/pdf_pubs/P1332.pdf[/url]
[url]http://www.ars.usda.gov/sp2UserFiles/Place/53102000/pdf_pubs/P1361.pdf[/url]
Hi Itag,
Thanks for your valuable contribution. I am interested i doing what u discussed in the forum. Can you send me examples (i.e excel)on this topic. my email [email]ariesbana@gmai.com[/email]
