Water Production Analysis
Guys,
Need your advice please...
I am working on a project determining the likely source of water production in oil wells.
The reservoir has a weak to moderate waterdrive.
I intend to do this by (1) Individual well analysis (i.e. determine if there is coning / flow behind pipe etc..that is water production is a localized well issue) and (2) Reservoir analysis (i.e. look for a uniform rising OWC, pressure depletion etc..that is water production is a general reservoir production issue)
Fellow engineers can you see any weaknesses and/or other things I need to consider here..or any other methods I should use!
CKP
