Hi all,
i want to ask about calculating waste heat boiler's efficiency to generate steam using hot flue gas from gas turbine WITH supplementary firing.
How to calculate the efficiency of waste heat boilers?
thank you very much
Printable View
Hi all,
thank you very much
Sorry if I am late in responding - The test code is PTC 4 ( I don't have electronic copy)
check here: [url]https://www.mediafire.com/folder/z12pqeqp10nle/Performance_Test_Codes[/url]
