Hysis Question: mass flow dont change with Temperature
Dear buddies!
I want to simulate a turbo-compressor (air compressor+turbine---->power)
it seems true! but i have a problem in sensitivity analysis : inlet Air Temperature
When i want to analysis inlet air temperature effect on Power, results are not correct.
i think it is due to constant inlet mass flow of compressor. as you know, in practice, mass will change!
because phro will change!
can any one help me?
thanks in advance!
Re: Hysis Question: mass flow dont change with Temperature
Hi,
Mass flow rate won't change with pressure & temperature. Volumetric flow rate changes with change in pressure & temperature due to change in density with pressure & temperature.
