Infrared flammable gas detection case studies
Dear Sirs,
Receive my greetings.
I work for instrumentation projects for many industries sectors, including water and oil & gas.
I´m working also for a technical presentation about gas detection technologies focused on infrared (NDIR) vs catalytic sensors.
With the purpose of complement my work I ask if you can advise about documented infrared gas detection case studies or histories, for oil & gas applications if possible, that have been completed in the last five years.
I really will appreciate any references you can give me.
Best regards,
Luis Cristóbal
Instrumentation and Process Control Projects Engineering
Re: Infrared flammable gas detection case studies
check some info here -
[url]http://www.sensidynegasdetection.com/Support%20Library/gas-detection/SensAlert%20Plus/Sensidyne_Gas-Detection-for-Natural-Gas-Processing-Plants.pdf[/url]
The oil and gas industry involves several manufacturing processes and upstream processes that require gas detection solutions to be used on a daily basis. Whether its offshore drilling and exploration, or onshore refining and production of gasoline DOD technologies offers several options to keep work environments up to code and safe for your workers. If you’re in need of a Class1, Div1 unit or need a different option in a non explosive environment, our sales staff will be able to assist in determining what is right for you.
The right equipment really depends on which part of the oil and gas chain you find yourself in. Exploration drilling rigs and production platforms are going to require portable units that are explosion proof and UL Certified. Other parts of the oil and gas chain, like refining, will require both portable and stationary gas detection monitors.
The petrochemical industry produces several toxic gases for workers. Benzene, ethylene, propylene, toluene, and a few others are commonly found in the refining processes. While H2S and SO2 are more commonly found in the exploration drilling and extraction platforms.
Gases in this Application:
Methane (CH4)
Nitrogen (N)
Hydrogen Sulfide (H2S)
Carbon Monoxide (CO)
Toluene (C7H8)
Ethylene (C2H4)
Propylene (C3H6)
Propane (C3H8)
check the standard IEC_61779_6 guide for use
Thank you for your reply!
Do you have information about real applications histories of infrared flammable gas detectors?
Maybe for oil and gas production or ship tankers companies, that has recently replaced catalytic gas detectors.
Thank you in advance,
Best regards!
