ipt type="text/javascript"> (fun
Results 1 to 5 of 5
Thread: How to understand aboout Uncertainty value in CRM Certificate
    Oct 2011
    0
    Dear All*
    I post to seek your consultance/experiences for explaination about the Uncertainty value in the attached certificate.
    Example:
    Standard value (ARV) = 0.0502%
    Uncertainty (U) =2
    I cannot understand that U >> much more than ARV* because U value here is not defined the fomular. There fore* Does this certificate is wrong?
    Could anyone understand* plesease help to share it. Especially* if you have any standard related to clear this problems* also open share it.
    I'm so appreciate*
    See More: How to understand aboout Uncertainty value in CRM Certificate
    Attached Files Attached Files
    Jan 2012
    339
    Re: How to understand aboout Uncertainty value in CRM Certificate
    Quote Originally Posted by namlexuannth View Post
    Dear All*
    Example:
    Uncertainty (U) =2
    I'm so appreciate*
    standard value +- uncertainty value
    i.e. methane 0.0502% +- 2%* can be between 0.0502 -2%=0.0492 and 0.0502+2%=0.0512
    Oct 2011
    0
    Dear Tassoss*
    Thank you for your answer*
    You've speculated yourself by understanding that Uncertainty value= 2% of true value* right? because it's unreasonable if accepted Uncertainty= 2 (It will be much more larger than true value) whether absence in the description of CRM's Certificate.
    But I wonder* Is this the exactly rule for all CRM Certificate? Because in some cases when you calculate under percentage of true value and use exactly itself is reasonable in both cases. What is your decision at that case?
    Jan 2012
    339
    Dear Tassoss*
    i haven't speculated anything. the stated uncertainty is always in the units of the certified value.
    link Point to another website You need to be logged in ,in order to see it.
  7. #5
    Oct 2011
    0
    Dear my friend*
    thank you for your kindly reply*
    In your certificate* the Uncertainty has the unit same as the Certified value's unit* that's the good CRM Certificate* so you are easy to understand.
    But my situation is different with yours. Please see in my attach certificate above (img-320141428-0001.pdf ) to instruct me properly. They are not define unit of Uncertainty* they are not defined the formula to calculate them.
    Once again* thank you for your sharing experiences.
  1. Replies: 0
    Last Post: 05-22-2013, 04:38 AM
  2. Replies: 0
    Last Post: 05-16-2013, 01:47 PM
  3. Know and understand Centrifugal Pumps
    By sharmeen in forum Mechanical Engineering
    Last Post: 11-22-2012, 04:59 AM
  4. Replies: 0
    Last Post: 09-08-2011, 04:17 AM
Visitors found this page by searching for:
Discussion forum and a library of videos and photographs related to the petroleum industry , Safety And Environment , Geology , Exploration , Drilling , Workover, Reservoir, Oil And Gas Production, Oil And Gas Process, Petroleum Refining, Petrochemical, Laboratory Measurements, Instrumentation & Control, Mechanical Engineering, Planning & Project Management, Pipeline And Fluid Flow, Electrical & Power Engineering, Materials Science &Corrosion, Civil & Structural Engineering, Engineering Certificates, General Engineering, Engineering Spreadsheets & Presentations, Engineering Software Tutorial, Petroleum News, Jobs, Self Improvement,Petroleum Club
