Now We can access Petroleum Community by domain www.petrolcom.net______________ website new domain www.petrolcom.net
Results 1 to 11 of 11
Thread: How do I design in have autotransformer in ETAP?
    Apr 2011
    2
    How design autotransformer in ETAP?
    I have autotransformer consisting of 3 single-phase auto transformers 400/220 / 31.5 kV and 267 MVA unit capacity or total capacity of 800 MVA
    Modeling it with a 3-Winding Transformer * but I can't understand in the section for "impedance" resistance for a 800 MVA оr for a 267 MVA should I enter?
    › See More: How do I design in have autotransformer in ETAP?
    Spons Circuit advertisement
    Jun 2010
    test
    43
    You need to read symmetrical components by blackburn to know the basics. You need to go back the basics of per unit calculations.
    Let's always remember that:
    ETAP is just a tool. A garbage input results in a garbage output.
    Sent from Mars using Tapatalk
    Oct 2014
    2
    Re: How do I design in have autotransformer in ETAP?
    Hi*
    when dealing with single phase transformers to be connected to form a bank of three phase power transformer* the impedance per transformer should be used. this is independent when it is connected as an auto transformer bank. But* since the auto transformer is like a three-winding transformer* the nameplate of the transformer will have illustrated three values of impedances measured with respect to each other (i.e. H-X* H-Y* X-Y). In this case* you have to solve the value of impedance per side of transformer (H* X* Y) because these data are needed in the power flow software. the formula for that is usually written in several excellent texts in power system. In the case of PSS/E* you will have to just input the nameplate parameters and the software engine will solve the required impedances.
    Oct 2014
    2
    Hi*
  7. #5
    Apr 2011
    2
    Thank's.
    I will use the impedance for a 267 MVA in p.u %
    Apr 2011
    2
    double post
    Mar 2016
    54
    [This link Point to another website Only registered and activated users can see links.]
    Feb 2013
    algeria
    0
    thanks himmelstern
  11. #9
    Mar 2016
    54
    I found an autotransformer on GIS or geoespatial diagram* for railway applications* it used for etrax module.
    and
  12. #10
    Aug 2014
    Sweden
    73
    Re: How design autotransformer in ETAP?
    Quote Originally Posted by fgm
    Modeling it with a 3-Winding Transformer * but I can't understand in the section for "impedance" resistance for a 800 MVA ذ¾r for a 267 MVA should I enter?
    OK so 3W TX
    If LV winding = 800 kva and if Teritry winding = 200 kva then HV winding will = 1000kva (sum) in most cases.
    Now you must check impedance Z% from manufacturer nameplate. With Z% and kva you can calculate R* X *X/R ratio.
    *very important*: depend on software make sure you calculate above values on correct base power (usually winding kva). I see many mistake from this error.
    Edit: i misread your best* what i say above is for three winding transforner* autotransformer might be different.
  13. #11
    Mar 2016
    54
  14. The Following User Says Thank You to himmelstern For This Useful Post:
    user82 (09-15-2017)
  1. ETAP v14
    By smzakaullah in forum Electrical & Power Engineering
    Last Post: 08-15-2015, 10:14 PM
  2. ETAP v12
    Last Post: 02-20-2015, 04:19 PM
  3. Etap 7
  4. ETAP 6 Ground Grid Design
    By muaaz85 in forum Electrical & Power Engineering
    Last Post: 03-11-2012, 11:04 PM
  5. need ETAP 6
    By PHILEMON in forum Engineering Software Tutorial
    Last Post: 10-15-2010, 08:09 AM
Visitors found this page by searching for:
