Hi Friends,
Could some body help me out, providing the Fluid Flow Measurement Standards -BS 1042 / ISO 5167.
Thanks in advance...![]()
Hi Friends,
Dear Friend,
I have ISO 5167(part 1~part4). Please leave your email at faizol@mset.com.my and then i will send to you.
Thank you.![]()
ISO 5167-1 Measurement of fluid flow by means of D.P. Meters - General principles & Requirements
ISO 5167-2 Orifice plates
ISO 5167-3 Nozzles and Venturi nozzles
ISO 5167-4 Venturi Tubes
Have fun!
Dorio
thanx
Thank you....X 100000000000000000000...you save me![]()
Thanks !
Thank you!!!!
Do you think these one ?
No ASME No Title
1 MFC-1M Glossary of Terms Used in the Measurement of Fluid Flow in Pipes
2 MFC-2M Measurement Uncertainty for Fluid Flow in Closed Conduits
3 MFC-3M Measurement of Fluid Flow in Pipes Using Orifice, Nozzle, and Venturi Errata - September 1990
4 MFC-4M Measurement of Gas Flow by Turbine Meters
5 MFC-5M Measurement of Liquid Flow in Closed Conduits Using Transit-Time Ultrasonic Flowmeters
6 MFC-6M Measurement of Fluid Flow in Pipes Using Vortex Flowmeters
7 MFC-7M Measurement of Gas Flow by Means of Critical Flow Venturi Nozzles
8 MFC-8M Fluid Flow in Closed Conduits : Connections for Pressure Signal Transmissions Between Primary and Secondary Devices
9 MFC-9M Measurement of Liquid Flow in Closed Conduits by Weighing Methods Errata - December 1989
10 MFC-10M Method for Establishing Installation Effects on Flowmeters
11 MFC-11M Measurement of Fluid Flow by Means of Coriolis Mass Flowmeters
12 MFC-14M Measurement of Fluid Flow Using Small Bore Precision Orifice Meters
13 MFC-16M Measurement of Fluid Flow In Closed Conduits by Means of Electromagnetic Flowmeters
14 MFC-18M Measurement of Fluid Flow Using Variable Area Meters
