Thread: UL-142 Horizontal Tank
Hybrid View
Previous Post Previous Post   Next Post Next Post
    Post UL-142 Horizontal Tank
    I recently UT inspected a 10 year old UL-142 Horizontal tank, diesel service, now Im looking for a way to calculate a minimum thickness, after some research I came up with a minimum thickness to be equal to the minimum thickness for overstand only the weight of the tank itself, because the diesel only means a 2.4 psi of pressure.
    Anyone Have any idea of how to calculate the minium thickness of ahorizontal tank?
    Any suggestion will be welcome, and thanks in advantage.
    Abdul Abud Pacheco
  2. Related Issue
    I looking for the UL-142 standard... I think the for us is in the that document. I'm going to keep my search and if I find something i'll let you know, I hope that you would do the same thing
  3.    Sponsored Links
  4. #3
    Finally I came with the solution for my problem, in the SP-001 document (from the steel tank institute) they came with this argument for declaring a tank good for service:
    if the minimum remaining wall thickness is more than 75%, then re-inspect in 10 yrs
    if the minimum remaining wall thickness is more than 50 but less than 75, re inspect in 5 years and locate corrosion origin and eliminate it.
    if the minimum remaining wall thickness is more than 25 % but less than 50 % take tank out of service, repair/renew tank as needed...
  1. Stability check for the underground horizontal steel tank
    By Kavinda Bandara in forum Pipeline And Fluid Flow
    Last Post: 12-22-2013, 09:12 AM
  2. Replies: 0
    Last Post: 07-21-2011, 10:31 PM
