| M.a.t.bal. 2.o Found links.....a bit old i think. 47mb http://www.9iv.com/down/soft/1395.htm Matbal v2.0 (سحئّ·ضخِبي¼) ×¢²لئئ½â-sn2sn Password is: http://www.9iv.com/ enjoy if u must cheers if it's any good, can someone upload it on some other fileshare & post. thank you.
__________________ |
| Somehow I managed to dowmload it. Here is the link: RapidShare: Easy Filehosting Installation runs OK, BUT it needs a license to be run.
| Hi asrakal, thanks for the links. I downloaded the license file from the 2nd link but it does not work. The messages say : 1. The desired vendor daemon is down (-97,121:2"")(MATBAL) 2. An EPS security device could not be found - please check and try again. Error Code : 54-105. 3. The application can not be started. A valid user license can not be found. Any body has some ideas to resolve ? Thanks.
| Thanks Yengineer. I had followed your guidance but still had the same problem. I did not find stand alone option during the installation. Many attempts done but no luck so far.
| Try this Go to registry Under HKEY_LOCAL_MACHINE\SOFTWARE\FlexLm License Manager Make a new string value called EPSLMGR_LICENSE_FILE then enter the address where you locate the license, eg C:\Program Files\EPS\MatBal2\license.dat See if it works It's not going to work if you are running X64
| Quote:
can you help you to download this soft matbal 2.0 i need it!!!!!!!!!!!! thanks
| Bookmarks |
| Tags |
| 2o , matbal |
| Thread Tools | |
| Display Modes | |
