#1
ASME Code
ASME Code The American Society of Mechanical Engineers Founded in 1880 as the American Society of Mechanical Engineers, ASME is a not-for-profit professional organization that promotes the art, science and practice of mechanical and multidisciplinary engineering and allied sciences throughout the world. The core values of ASME are rooted in its mission to better enable mechanical engineering practitioners to contribute to the well-being of humankind ASME Code The American Society of Mechanical Engineers ASME B16.36-1996 ORIFICE FLANGES This standard covers flanges ( similar to those covered in ASME B16.5) that have orifice pressure diffential connections. Coverage is limited to the following: (a) Welding neck flanges Classes 300, 400, 600, 900, 1500 and 2500 (b)Slip-on and threaded Class 300 http://rapidshare.com/files/65947692...ce_Flanges.pdf ASME B 1.1-1989 Unified Inch Screw Threads( UN and UNR Thread Forms This standard specifies the thread form, series, class, allowance, and designation for unified screw threads. Several variations in thread form have been developed for unified threads; however this standard covers only UN and UNR thread forms. For easy reference, a metric translation of this standard has been incorporated as Appendix C. Appendix A through C contain useful information that is supplementry to the sections of this standard http://rapidshare.com/files/65948198...reads_1989.pdf ASME B16.11-2005 Forged Fittings-Socket Welded and Threaded This standard covers ratings, dimensions, tolerances, marking, and material requirements for forged fittings, both socket-wwelding and threaded, as illustrated in Tables 4 through 8 and Tables 1-1 through 1-5 inclusive in this standard http://rapidshare.com/files/65948702...d_Threaded.pdf ASME Guide for Gas Transmission and Distribution Piping Systems,2003 ASME Code for Pressure Piping, B31 http://rapidshare.com/files/51334242/ASME_B31_1_.8.pdf Power Piping By The American Society of Mechanical Engineers * Publisher: The American Society of Mechanical Eng * Publication Date: 1977 * ISBN / ASIN: B000PCNVB8 PDF, with bookmarks http://rapidshare.com/files/49920011/power_piping.pdf Welded And Seamless Pipes - ASME http://rapidshare.com/files/49892044...LESS_pipes.PDF ASME B31 SERIES http://rapidshare.com/files/18809069...B31_SERIES.rar ASME B16.5a-1998 Pipe Flanges and Pipe Fittings This standard covers pressure-temperature ratings, materials,dimensions, tolerances, marking, testing and methods of designating openings for pipe flanges and flanged fittings in sizes NPS 1/2 through NPS 24 and in rating Classes 150, 300, 400, 600, 900, 1500, and 2500. Flanges and flanged fittings may be cast, forged, or ( for blind flanges and certain reducing flanges only ) plate material as listed in Table 1A of this standard. Requirement and recomendations regarding bolting and gaskets are also included http://rapidshare.com/files/65947628...d_Fittings.pdf ASME B36.19M-1985 Stainless Steel Pipe This standard covers the standardization of dimensions of welded and seamless wrought stainless steel pipe http://mihd.net/nyodrg OR http://rapidshare.com/files/74409570...Steel_Pipe.pdf ASME Boiler and Pressure Vessel Code - Section 8 - Division 1 - 2007 Rules for Construction of Pressure Vessels By ASME Publisher: ASME Publication Date: 2007 ISBN-10 / ASIN: 0791830683 P1 http://mihd.net/idk92c P2 http://mihd.net/rz7n0t P3 http://mihd.net/mzjfu1 ASME Boiler and Pressure Vessel Code - Section 8 - Division 2 - 2007 Rules for Construction of Pressure Vessels - Alternative Rules By ASME Publisher: ASME Publication Date: 2007 ISBN-10 / ASIN: 0791830691 P1 http://mihd.net/r5v9m4 P2 http://mihd.net/7iyuxa P3 http://mihd.net/x0qicg ASME Boiler and Pressure Vessel Code - Section 8 - Division 3 - 2007 Alternative Rules High Pressure Vessels By ASME Publisher: ASME Publication Date: 2007 ISBN-10 / ASIN: 0791830705 http://mihd.net/kq24ro ASME SEC 9 http://rapidshare.com/files/84970950...PVC_SECTION_IX- 2007_QUALIFICATION_STANDARD_FOR_WELDING_AND_BRAZIN G_PROCEDURES__WELDERS__BRAZER.html Pressure Vessels : ASME Code Simplified By Phillip Ellenberger * Publisher: McGraw-Hill Professional * Number Of Pages: 320 * Publication Date: 2004-06-04 * ISBN / ASIN: 0071436731 http://mihd.net/i9j2p0 BPVC-VIII-3 - 2004 BPVC Section VIII-Rules for Construction of Pressure Vessels Division 3- Alternative Rules High Pressure Vessels By ASME * Publisher: ASME * Number Of Pages: 0 * Publication Date: 2004 * ISBN / ASIN: B000S35PZE Product Description: This Division of Section VIII provides requirements applicable to the design, fabrication, inspection, testing, and certification of pressure vessels operating at either internal or external pressures generally above 10,000 psi. Such vessels may be fired or unfired. This pressure may be obtained from an external source, a process reaction, by the application of heat from a direct or indirect source, or any combination thereof. Division 3 rules cover vessels intended for a specific service and installed in a fixed location or relocated from work site to work site between pressurizations. The operation and maintenance control is retained during the useful life of the vessel by the user who prepares or causes to be prepared the design specifications. Division 3 does not establish maximum pressure limits for either Section VIII, Divisions 1 or 2, nor minimum pressure limits for this Division. Rules pertaining to the use of the UV3 Code symbol stamps are also included http://rapidshare.com/files/65752412/ASME_VIII_2004.pdf Welded And Seamless Pipes – ASME http://rapidshare.com/files/49892044...LESS_pipes.PDF
__________________
http://groups.yahoo.com/group/Arabs_petroleum Egyptian Petroleum Video Library http://www.egpet.net/library |
#2
thank you
__________________
#3
Shokran, and Gazakom Allaho Khairan.
__________________
#4
__________________
#5
Thnak you eng mohamed elhagar
(swat)
__________________
#6
__________________
#7
the links are not valid. Please upload again
__________________
#8
plz upload again its deleted.
__________________
#9
Required ASME B 16.34
Kindly give link to ASME B 16.34
__________________
#10
Thank you! I'm looking for SECT VI and SECT VII; anybody has them?
__________________
#11
Thank you! I'm looking for SECT XII; anybody have it?
__________________
#12
Thanx
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| API Code Collections | Mohamed | Oil And Gas Process | 92 | 02-05-2010 01:10 PM |
| AST 269 or ASME B 36.19 | main_zia | Instrumentations | 3 | 10-16-2009 12:09 AM |
| ASME Boiler & Pressure Vessel Code – 2004 (Digital Version) | Nasir | Mechanical Engineering | 48 | 09-12-2009 10:52 AM |
| (ask) ASME IX | prasetyohse | Mechanical Engineering | 6 | 03-05-2009 05:35 PM |
| Need Help for SHELL code and Chinese code for fire protection | sumit.alok | Safety And Environment | 0 | 06-24-2008 04:08 PM |
